Hy guys,excuse my poor english first. I bought a great xperia active last week and i have a a question...
How to acces the info ( music, video, ) on the SD Card. ?
For example I installed the sony pc companion , i have copied from my pc some ringtones. How can i acces those rongtones from my telepfone ? Or how to send them with bluetooth ?
From my ringtones settings they work...selecting wich you want but to transfer them i don`t know how...
I have a Samsung smartphone too and the samsung has a folder named "My Files" where i have music, video and other files practically an entrance to the folders of the SD Card.
So I want tho get help from you to explain iff possible the same thing from the xperia.( An icon or an application that sends me directly into the data of the card .
PS.In the menu of the phone we have the icon "Gallery" - here i see the pictures wich i made and some videos preinstalled of billabong and not the files i have copied from my pc too.
the root directory of my sd card...
If possible to help me...thanks. Maybe is a way and i don`t know...
Thanks...i downloaded it and install it but not a shortcut to it
After installed the application doesn appear in the menu .. where should it be ?>
It should be on the applications menu. You can also add a shorcut to your Home screen.
Offcourse there was at the last page in the menu and i didn`t see it,
Thank very much that solved a big problem form one week...
So if u don`t have internet acces on the phone and without File Manager this thing could not work.
Thanks again !
You're welcome!
