Quirky problem, the Screen Lock Sound is inactive, It's selected in the sounds menu as is haptic feedback and audible selection. All volumes are at max. I have rebooted and even done a setting reset Anyone any ideas?
All volumes are set to high
this is odd
i just checked mine and there;s no sound...
i dont want to update the software again
'm sure it worked before..
got it...
did you installed any app related to music..?? or ringtone..?? some audio manager/..?
whatever you downloaded..forget it
install this application..
i know main purpose is to hide all personal stuff but still download it , this acts as an audio manager too
so when you will open that application..
forget the pop up which says long press on audio manager to access hide it pro..
you will see 6 sounds option..
the 5th will be system sound.. make it full 7\7 and check your lock screen volume
Slim.... You're good. It was the system volume! Where's that menu in the arc? ( without the audio manager)
there isn't a way to get to the system volume for some reason, you need third party apps
FtThank u, One for SE on the next sw update? Hoetw do we ask, do tbey read the forums?
that would be great, but I don't mind using a 3rd party app, like Quick Settings
https://market.android.com/details?id=com.bwx.bequick&hl=en
since I use this app to control many other things
haha it worked :smileygrin: :smileygrin:
