Hi .. I bought neo v on jan 14 2012.. After i bought it, the box seal was opened before me in the shop and the seal was fine. That time I dont know that neo v comes with a screen guard. When I came home and checked the contents of the box on the label there is a screen guard written on it. I went back to the shop and asked about the same. They said that the box was opened right before and we cant help it if it does not come inside the box. How can i deal with this?? Is this the fault of sony ericsson or the shop keeper is cheating me??? Please suggest.
I don't know about lawyer
but from my 3 xperias all came with pre-installed screen protector, the thiner the better, trust me, if its to thick then there will be some issues with the digitizer/touch screen.
if you ever want to replace it, or when it gets scratched use this ZAGG
I like the idea that it is pre-installed that way you don't have to worry about installing it and leaving air bubbles underneath, this varies from market but in some countries they get an extra one, some other markets they get a bluetooth headset, etc.
are you sure its not already pre-installed?
Its not on the screen and its not in the box. Thats what Im confused. Is tht missing or im being chaeted??
if you have a camera, take a picture of the edge of the screen then on your computer zoom in, and you might be able to see the pre-installed screen protector
No . Im sure its not there.
How can you be so certain, I've seen this happened before, that some users said it wasn't included but they later realized it was pre-installed. just take the picture
Sorry uliwooly I did it after you said it. I cant see anything in the picture.
can you post it here?
Here is the image for your kind reference
I see a screen protector, if you take a closer look you will see it, or take another picture of the edge of the screen then zoom in and you will see it
