I have an annoying problem over te cell phone that after the screen is locked it starts to blink
and flash after every 5 mins it blinks for around 5 times
I have 2.3 Gingerbread OS.
I re-installing OS but nothing.....What should I do now???
please HELP.....!!!
Hi vasilis.lets
Have a look at these threads and let us know how you get it on
Screen Blinks every 10 secs after locking in Xperia Neo V
Display keep turning on/off automatically
Live with Walkman screen turns on suddenly
My Xperia X8 display light automatically turns on, even if not in use
does it happen right after you repaired the firmware or after you installed or synced some apps?
This was happend after one month i bought the phone .i made format of all aplications and continue the same thing.my firmware is 6.0.A.3.73
do you have a protective case? or extra film protector?
yes i I have both of these....but it was blinking/flashing before i bought these
try w/o the protective case
is the protective case the realy problem???? and why???
Hi vasilis.lets
