Hello all,
I bought my Sony Xperia S today and it says i need to be able to update it from gingerbread tot ice cream sandwich.
I have no clue on how to do this, if i connect my phone to my pc using the usb cable, and starting thesony pc companion software it says there are no updates for my phone. How can i update it to ICS??????????????
Help would be much appreciated.
ICS is not released for your phone yet
It could be a minor update, if yes then try to use this
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
________________________________________________________________
or
Sony will start the ICS release for the Xperia S at the end of this month
When you find out let the rest of the world know wont you
