This may be a little off topic, but my screen protector has collected too much dust, where it is a pain to watch
I want to remove it ( the default protector that came with the arc s), but i do not know if the so called ' scratch resistant screen' is actually effective
I would just like to hear from users that do not have a screen protector , and the screen's condition.
no no, the digitizer/touchscreen it's made out of scratch "resistant" glass, not scratch proof, which means it's harder to scratch it but not impossible. and the shatter proof film is in case you break your digitizer you can still use it w/o cutting your fingers or w/o it falling off
its a shatter proof film on top of a scratch resistant glass, so yeah you can remove it
OH ! so it basically has a screen protector under a screen protector ? o.O
No need to buy one then
Thanke (Y)
OH ! i understanding what you are saying now. So that tiny piece of film holds the glass together and prevents my actual screen from scratching. Thanks for clearing things up
You have the LCD then on top the Digitizer on top you have this film
the LCD it's the screen
digitizer is the touchscreen
film is the shatter proof film
check the teardown of the Xperia Arc
http://talk.sonymobile.com/message/111994
so is thet shatter proof film scratch resistant? Is it high quality?
the shatter proof film it's not that great, it gets scratch quite easily, you can put a scratch resistant or scratch proof film on top, like this one
