I am assuming that you treid everything listed by users above
Take the battery out of the mobile for hours and see if you face the same problem
if not then ;
________________________________________________________________
Backup everything as it will erase all data on phone (sms, contacts,apps)
Update/Repair your phone via PCC or SUS
PCC (PC COMPANION) – Repair your software with this .First do the setup without connecting your mobile to pc.(only connect when you are asked to).
Do it as follow >> PCC > SUPPORT ZONE> SOFTWARE UPDATE> REPAIR SOFTWARE (written with blue)
PC Companion http://www.sonymobile.com/global-en/tools/pc-companion/
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
Hello,
1st You are in the xperia S forum and
2nd I don't know...
Arc S is in another forum area perhaps place your post here....
http://talk.sonymobile.com/community/support/xperia2011/arc
Hi tom421 Thank you anyway I'll stay hopeful that some body can help
Tried that but no luck, Thanks anyway
No luck there either but thanks anyway
if not then ;
or
