Is there a way I can restore back the default camera application? A smart kid was playing with my phone and I think he uninstalled it :smileysad:.
I guess it can be done through restore factory settings but I dont want to do that as I will lose the the Jelly Bean update. Please suggest.
open the app drawer do you see the camera? if you do then long press (press until it vibrate then drag it to the homescreen
if not then
settings > apps > all > scroll to the bottom > camera > enable.
