You have some apps acting up,remove task killers,antivirus etc.
I'm assuming your music is stored on your SD card?
Do you have some antivirus?
Does the same occur in safe mode?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
Great.
