How to remove/reset/clear/delete intellisense data from Xperia x10?
On my Arc, I have what it calls the 'international keyboard' rather than 'default' and I have been trying to find a way to delete words from the user dictionary. I am pretty sure I used to be able to open it and delete individual words without having to type them in the text input area, but the facility no longer seems to exist. I also tried deleting them by long-pressing the unwanted words, but that doesn't work for me, so I am stuck with suggestions that were created when I mistyped words in the past. As people who know me will be able to confirm, that is a lot of typos.
Are there different versions of the default or international keyboard on different phones, I wonder?
I would think different keyboard versions for different Android versions.
Use Default Key board...
Remove user dictionary and "Don't use dictionary" option works only for default key board.
I was having this problem because I had not selected Default Key board.
Thanks for your help....
All the options mentioned by u were not working because I had not selected default key board.
After selecting default key board I am not getting any suggestion.
Great relief.
Thanks to all for helping me for this....
Great! Glad that you have finally sorted it out.
Can feel your relief ....
