How to remove/reset/clear/delete intellisense data from Xperia x10?
Thanks for suggestion, I thought it will work, but it not. Clear cache option is disabled because cache is showing 0.00 B. i.e. there is no data in cache.
I also tried...
Setting >> Language & Keyboard >> User dictionary >> and removed user dictionary...
But it does not work.
Hi, if you do not wish to use the dictionary, you can actually 'disable' it.
To do it, launch Messaging app, tap on the 'Write message' area to bring up the keyboard. Tap on the 2nd key from right (a spanner icon)>Quck text settings>Word suggestions>Don't use dictionary.
Hope this helps.
I am not sure which key are u talking about, can u please tell me exactly which key.
The bottom roll, 2nd from the right, the one next to Enter/Return.
at the bottom, next to Enter/Retun there are two navigational keys "<", ">". I think my keypad having different settings.
Input method was not Default, after selecting it I was able to go to "Quck text settings" but I found that I had already selected "Don't use dictionary" option through Settings >> Language & Keyboard >> Default input >> Quck text settings. but it does not work.
Also tried...
Strange .... no word suggestion from mine when I select 'Don't use dictionary'.
Maybe the problem lies with the keyboard that you are using, you need to 'disable' dictionary there. Suggest you look for this setting on the keyboard that you are using.
how about unchecking "learn words" ?
