hi friends i am here for a solution about to stop the repeation of the songs while playing in the music player on my
xperia neo v
my bad....
indeed the songs starts again even after making a playlist..
there'sno way to do so until and unless you install another music appliation..
try what uliwooly suggested above and see if it has the option to turn repeat off...
you can also try winamp..
to nabeel - the music player in all xperias is the same so you can also help
lol
i just realised that i m also facing the same thing ...
(how can i be so stupid... i mean i already knew that all xperia have same player ... oh god what has happened to me :smileycry:... slim thanks for reminding again.)
unfortunately, no solution for it
get a different music player ....
yo yo yo honey singh :smileygrin::smileygrin:
ahh oky well the problem found and solved
... good going guyz
try Neutron player from android market... its the best music player for professionals.. rest should use other music players pls :smileygrin:
aah i don't want anther application
my arc starts to die... so i'm better off with the stock music player
let him try./
thank you guys for the reply
slim r u serious
how many apps(total ) u have in ur arc ??
i have 60 3rd party apps and my ARC S runs flawlessly
i have 56 applications
40 on sd card and 16 on phone memory..
i just avoid keeping app which i wont use..
i mean the stock player is good..
