Hey i want to know if i go to sony service center and change my xperia go housing will it still be waterproof after that ? and will they change the blue thing also ?
You can contact your local xperia and ask about that:
http://www.sonymobile.com/global-en/support/contact-us/
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
If you turn to an authorized service center the phone should still ensure it IP classification after a service.
As Alexdon said above, you should contact your local Xperia support team for more information about how to get in touch with an authorized service center.
They will.
