can somebody tell me what is this my phone is stuck on this for 15 min now
The screen you see indicates that the phone is repairing the file system.
This can take a while so connect the charger and leave it be until it's finished.
Image will not appear until mod user accept it.send pic link here
You need to upload the image to something like box and post the link/url here
it's a triangle with a screwdriver and a wrench and a blue line going under but now it finished but now i'm facing another problem the album app wont update -.-
Thank you very much now i'll just have to keep down and wait for a bug fix update
I'm having the same issue. I had the same screen.
But it's lasting more than two hours now. I can't enter my phone and it's stuck on a screen with theSony logo.
how long did that process last for you?
