Your DRM keys are forever gone, no, you can not restore them, in some countries unlocking the bootloader void your warranty. Even if you relock the bootloader the DRM keys will be missing
but i have seen in xda developers it is possible to get ur warranty back!!!
I haven't seen that, I hope I'm wrong but check the XDA forum
ill check thanks,,
but now i got a new problem...
check this for the problem http://talk.sonymobile.com/t5/Xperia-U/Xperia-u-Is-Not-switching-on/m-p/422159#U422159
How I can relock bootloader?
hi mhossain98
check this link
2nd post!!!
http://forum.xda-developers.com/showthread.php?t=1527159
hi mhossain98
check this link
2nd post!!!
if it helped give kudos
