Hi All,
Please dont buy any xperia mobiles :smileyconfused:. It just sucks..:smileydevil: battery drains soon:smileycry:, problem with notifications and even problem with network:smileyalert:.
The battery status bar also have many bugs :smileyplain:. Once you restart your phone sometimes you will find a huge deviation on the status:smileyshocked:.
Does sony bothered to resolve these bugs
or they just want to launch new mobiles in market :smileylove:. !! Its just stepping towards the path of Nokia to get it shut down by launching mobiles with bugs.:smileylaugh::smileylaugh::smileylaugh:
i hope some of the sony moderator will respond or else again it will turn up as a discussion asusual and nobody will gain anything.!!
No more Hopes from SONY... :smileyangry::smileyangry::smileyangry:
Smart strategy if you wanna loose costumers...:-) I still hope they take care of us with experia P
