Is it normal that if I remove the micro sd from my st15i it reboots itself?
Sometimes my cell phone reboots on its own and I think that my memory is the cause of this.
Can someone help me and look for a solution?
PS: sorry if there are some mistakes, I'm italian.
That shouldn't be the case unless you have apps that were on your SDcard and the system is looking for them
I agree with Uliwooly, however maybe a format to the memory card would clarify if this was related or not.
Just make sure to backup the content of the memory card to a PC before doing this.
I moved on the phone two applications which were in use most of the time and it seems that now my phone doesn't reboot if I suddenly remove the sd card.
The only issue is that if I want again to use an app on the sd I need to reboot my phone because otherwise it can't find the app XD
I'll let you know in the future if the random rebooting problem is solved.
any news on my account uliwooly? and what's going on with the XperiaX10.net and Xperiablog.net?
