Hi, I have an Xperia Neo and the rear speakers have suddenly become almost inaudible even at maximum volume, now i can't hear the notifications, it ringing or anything coming from the rear speaker...
what should i do, i have a local-ish Sony store i could take it too, does the guarantee cover this, will they be able to repair this fault or perhaps replace the device?
Thanks for your support, I'm very pleased with the phone so far as i am with everything from Sony!
Kind regards,
Callum Lewis.
okh
it confirms that its not a software problem but a hardware problem
visit your nearest service center to get it done
after getting it done,, remember to visit here
and since it is not a physical damage, your phone might get repaired free of cost
do a service test and see if it is working
dial *#*#7378423#*#* in dialer > servic tests> speaker> after that stereo speaker
do tell the results
Thanks for your responds, i did the service test like you suggested and on "speaker" it's still only just audible if i put it to my ear. couldn't see the "stereo speaker" option but i did test the "earphone" which is working correctly.
Thank for your support, i will take it to my local Sony shop in Hereford and see what they can do.
