I heard Ray is getting hot, really hot, right at your ear nd back panel, I think this is mainly caused by the processor. I have never experienced, plze tel anyone to the thermal problem ?:smileyshocked:
you heard it or experienced it ??
well yes..my arc gets hot ie upper back panel.. but its not that much..
some users have faced this problem of getting over heat but its not an issue with all the phones..
if yours doo the same ie overheat get a replacement of your phone
i think sometime bad 3G connection that makes your phone work harder or maybe to many program and connection on the same time:smileyconfused:
3g connection - well it depends on operator to operator..
as i mentioned above..you dont have to worry..
some faulty handsets overheats..not all the phones do..
