Hi everybody...
Sorry to bother you, but its really bugging me... I recently bought a Sony Xperia U, and I accidentally changed my wallpaper settings to random wallpaper... Problem is, that I can't find the place to change it back to the way it was... I've searched through all the settings options, including specific options of the camera and gallery, and nothing... Please help me if you can...
Thanks for the attention given...
Ok, found the problem, sorry it was actually due to an app... I'm so sorry, and thanks Johan for the attention...
You can change the wallpaper by pressing menu key > wallpaper.
Now choose the wallpaper you would like to use.
I already did that, and for I assumed it was done... But it keeps changing the wallpaper randomly from one folder... Even if I choose a wallpaper from a different folder it changes back to the previous one and maintain the random settings...
Hi, may I know how did you find which app caused this problem? I have been experiencing this for a while and it is really bothering me. 😐
I was using Zedge app and didn't remember to uncheck the box that enabled the random wallpapers...
