I just came across this video on youtube (link: http://www.youtube.com/watch?v=MKJlrSIrKiY ) and I just noticed this.. see the pic below.
As you can see the encircled one looks like a quick selection to some tools. I don't have that. Is that normal? O.o haha.
-- After I updated my XP to ics, I seem to have a problem about the notifications. Whenever I get sms, it would just vibrate for a short period of time. No ringtones.. 😕 Any solutions? Thank you.
Hi Cristian 15, For Notification issue,
Restart the Mobile will fix this..... I hope its a bug in FW
- the answer to ur first part is dat it is an application available on the play store - Notification Toggle !! itz really helpful in my view better dan the tool widget provided by sony and has a wide array of options to keep on the notification bar !! also it doesnt consume any ram(just 3.5mb) and neither does it drain the battery !! the link is
https://play.google.com/store/apps/details?id=de.j4velin.notificationToggle&hl=en
-the answer to ur second ? is dat it is a bug with the firmware !! xpect another update to fix it
plz mark as correct if u find my post useful
Thank you. :smileygrin:
