After updating the pc companion software, the syncronizing fails from the gmail to the phone. It states that there are 'currently' syncronizing problems, but this will be re-established soon...(like i a week or so?)
Syncronizing from the pc to the gmail account works fine.
Try to run a master reset on the phone and configure your Gmail account again and check if the sync works properly.
Backup any personal info before doing a master reset, but in your case I assume that you have everything synced?
I reconfugured my gmail and tried to sync once more with the same result. Now 48h later, everything is in my phone-calender without me doing anything...google spooks.
Thanks for the help.
