Since last update my arc s I have the following problem: when you open a link the browser opens it twice!
repair in PC Companion and the problem persists.
Sorry for the English but I am using google
Thanks for the help!
Only applications principally with twitter, use twitter from the browser and gave no problems
Had already reset the browser to default settings, including repair from pc companion and I even opened the two windows to open any link.
As for what you suggest, ask, because there was this problem before?
I think it's an app acting up, repair your phone and do NOT install any app, use your browser and see if it open 2 taps
unrelated topic, if you have some time please check this thread
Using twitter since the browser does not open the windows.
I'll use it until it is resolved so that, imagine that with an update of the app should be addressed.
Thank you very much for the recommendations and for your attention!
Anytime, try using Google Chrome, and see if you get the same problem (don't forget to disable the other browser)
