Hy! I just updated my Xperia Arc S to ICS and i think i did everything that the PC Companion said, but after I finished everything and tried to turn on the phone after vibrateing (normally) apeard "SONY", but after that an exclamation sign in a triangle and a phone appeared (something like this: http://www.hardreset.eu/images/motorola_droid_hard_reset6.jpg) and the phone automatically turned off! I tried to turn on the phone several times, but allways the same gif appeard... What should I do?
Backup everything as it will erase all data on phone (sms, contacts,apps)
Update/Repair your phone via PCC or SUS
PCC (PC COMPANION) – Repair your software with this .First do the setup without connecting your mobile to pc.(only connect when you are asked to).
Do it as follow >> PCC > SUPPORT ZONE> SOFTWARE UPDATE> REPAIR SOFTWARE (written with blue)
PC Companion http://www.sonymobile.com/global-en/tools/pc-companion/
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
or
