Hi guys,
I have a problem when i try to update my Xperia S 6.0.A.3.73 to 6.0.A.3.75
when i have turn off my phone and push the button to decrease the sound, i got a blue screen of the death on my computer.
I'm belgian so i can speak french too.
Turn off firewall and antivirus and then try this
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
________________________________________________________________
or
i can solved my problem, i have used an other computer and it's worked !
