Hello,
i have new problem with 4.1.a.0.562
iupdated my arc s to 4.1.a.0.562 and its work fine but there is a problem that when i working with my phone or running some app like camera or gallery , my storage ( Sd card ) will reduce!!!
for exapmle i had 1.2 Gb free space in sd card but when i worked phone my free space reduced to 1.0gb free and after a while 0.88Gb
I installd ics on xperia ray too i got same problem!!( sorry if my english is poor i hope u undrestands my mean):smileyplain:
Nah! the best way that i found was Repairing
All Problem such as ( Sd problem- Camera Quality problem- ringing on silnet mode problem ) Fixed in Both xperia phone Ray and arc ws
sorry guys i forget i got new problem too in 2.4.3 when i was connect a Storage to OTG cable my phone was messaging Un supported device but now in ics when connect there is no massage cuze phone didnt detect my storage
what is this new problem?
What format is the external storage in (ie: FAT32 or NTFS)? As far as the storage space goes, this can happen as applications start to cache data. You can clear the cache of applications by doing this:
Main menu > Settings > Applications > Tap on the individual applications > Clear Cache.
What are your thoughts about this forum? Let us know by doing this short survey.
arc s*
