I have xperia arc (lt 15i)
The display is getting grey many times when i lock my phone.
But few days before the screen was flickering.
Nw the screen is not flickering but it is going grey many times.
But yesterday I charged my battery to 100% and the problem hasnt occur until.
The sony service center said me to replace the display which will cost around 7K.
Is there problem with battery or screeen??:smileyconfused:
The cost involved with replacing the screen would be up to the repair agent, you would need to speak with them directly regarding that sorry.
What are your thoughts about this forum? Let us know by doing this short survey.
I think it might be the screen, but first try this
repair your phone with SUS or PCC and if the problem persists then most likely its a hardware issue, you could go with a new battery first as its cheaper but most likely it will be the LCD
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
I have udated phone yesterday only
BUt when i charge the battery to 100% it is working fine.
yesterday there was problem
but now it is working fine.
if I change the lcd how much money I have to spend for it???
