My x10 mini has up until yesterday had no problems showing different calendars at a time.
But now it shows no calendars at all, except for Week Numbers. All days have the entry "All day: Week XX". I have tried:
- logging on to the Google Calendar from the laptop and turned Week Numbers off, but it stays on the phone.
- updating the phone
- synchronizing the phone/calendar
- turning auto-sync on and off
- clearing cache
- rebooting the phone multiple times
I have found solutions for other phones which include going to the calendar and pressing the menu-key. But nothing happens, so it appears the x10 mini does not have that function.
So my questions are:
What happened to the calendar?
What can I do to correct it?
I have searched this forum for answers as well, but have had no luck finding a solution for this problem. I really hope you can help me.
Thank you in advance.
make sure you sync your contacts with google
Done.
Is there a way to send all text messages to the SIM card?
Something better than that
SMS use
backup & restore SMS
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
and for your MMS use Save MMS
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
Thank you for all your help. The phone is nearly back to normal 🙂
anytime
