I'm having a problem with the standard agenda application on the SE x10. Quite often I use the agenda application, but suddenly it was completely empty. All the events seems to be erased from the agenda.
Does anyone know how to fix this problem?
Fantastic! thanks Suze. It was starting to really irritate me and all the information I could find was that the problem was with google.
I was panicking that I would have forgotten something, but all entries and reminders sucessfully returned.
Thanks again
I spoke too soon. The problem is back again. Calendar says one thing on the phone and something else on google. The agenda doesn't display anything apart from a message saying tap here for further entries, but when you tap it doesn't do anything.
To add salt to the wound the phone has now decided to switch off and restart itself. I had this problem a while back and my phone provider sent it off for repair. It worked ok for a couple of months but now the problem has returned.
I have also noticed that the phone is very slow to display messages, phone contacts and calendar (when it was working). I don't have much data on it and i am a very light user.
Very disappointed in this phone. I spend more time trying to find out whats wrong with it than use it!
back up everything and then repair your phone with update service
