Did se release new fix or firmware version for current os? I saw some website showing minor firmware update for x8. I still love se current os.the ui is nice,and i dont mind staying with current os(2.1). as long as its officially from se. Thanks in advance
Oh yes, I have just checked on my phone and there is no update available for me at the moment. To ensure you have the latest software Download either Sony Ericsson Update Service and or Sony Ericsson PC Companion which will make sure you are up to date.
Hello, do you have a link to the website that you seen it on?
To check for any update, just connect phone to PC Companion via USB. You should be prompted if there is.
http://www.ptcrb.com/ctiastaff/complete/view_complete_request.cfm?modelid=17877 theres the link.hope it'll help.
My advice for you is to update phone through PC Companion or SE Update Service ONLY.
Thanks for the tips, ill try it, and see how,,because the firmware's release date kinda new and makes me curios.thanks moderator:-)
Welcome .... It's just a 'plug' away to find out.
anyone tried the new software?
can you post your benchmark results in Neocore and Quadrant
Thanks a lot
