Hi!
I have a question for SONY:
As you know, you offer us the posibility to unlock the bootloader, wich is cool, but i don't need to change the firmware.
Has sony considered de posibility of giving us, (even if the warranty is voided), the possibility of having root access to the phone?
A lot of us like to have the official firmware installed, but we need root access for some apps to have better control of what we can do with the phone (for example, to use a dedicated firewall).
Thanks in advance for your time.
Exactly. If i root the phone, i will root the .58, OTA to .62, and then make the modifications.
I do not need to remove any system app, the ones i don't want, i disable the autorun of them, and also block them with droidwall and problem solved
