Hi, i just bought the Xperia S and have problem in using the PC companion to update the software. Always return the Server Overloaded error message. I checked the other communties that this happened on other models too. So, what can I do? Can I DL the update separately and install myself?
Thanks!
try this instead
Update Service (SEUS)
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
try this instead
just for future S users, can you check if this app works on the S
Backup & Restore app (thanx)
http://talk.sonymobile.com/message/141167#141167
thanks so much! the Update Service software is working.
I can try the app and where can I dl the backup and restore app? under google play?
Hi @matsuken
Unfortunately it is not available in the Google play, try out the link posted by @uliwooly the links to download the application is perhaps available there...:-D
it does work, another S user tried it
I updated my Xperia s the other day using pc companion
your lucky you got the companion to see the phone
