Hi, i have brought a new xperia play from amazon, it came with ice creme sandwich 4.0.3, it hasnt got any pre loaded games, i was wondering how do i get the games, as it comes with crash bandicoot and a few others.
thank you in advance
check this thread, how to sideload apps
http://talk.sonymobile.com/thread/36355
Thank you, also if i did 'factory data reset' what would it do? i'm thinking of starting fresh, would it keep the beta ics or would it go back to gingerbread?
It would keep the version of ICS you have currently.
Hi, i have done it, but now i am missing my touch keypad, To type letters?
edit- did a reboot and it came back!
I am still having problems, i can't go back to stock, since i brought it is causing me nothign but problems, lag, games crash and now the whole screen keeps going fuzzy, then normal and back again, i would like to go back to stock but on pc companion 'repair phone' it says i can;t update due to modified version on my phone, i don't know much about the phone so im stuck
that's because you unlocked the bootloader, why did you unlocked it?
this is how to relock it
http://forum.xda-developers.com/showthread.php?t=1618635
I never touched nothing, i brought it 'used'
ok, they unlocked the bootloader, relock it and then you'll be able to use SUS but remember that there isn't ICS for the Xperia Play, the last update was 2.3.4
Xperia Play 2.3.4 minor update 4.0.2.A.0.62
http://talk.sonyericsson.com/thread/29378
Ok i don't mind, i just rather it working normally as that ics it was on is running slower than anything, that link u gave for relock bootloader, doesnt say anything ?? how do i relock the bootloader?
thanks for ur efforts
