Hi, i have brought a new xperia play from amazon, it came with ice creme sandwich 4.0.3, it hasnt got any pre loaded games, i was wondering how do i get the games, as it comes with crash bandicoot and a few others.
thank you in advance
you should have an app to get the games.
The only app i have is Play store to buy android games, if i search in crash bandicoot, it doesnt exsist.
it doesn't seem to work with ICS since Sony is not going to release an ICS update for this Xperia
http://forum.xda-developers.com/showthread.php?t=1679670
Ok thanks, so i will just buy the games of Play store
or can i get that from the link
no problem, if you decide to downgrade check the link above, enjoy ICS
Is it possible to install the play suit on that link above, on ICS or is it a definately no
I don't have ICS on my play so I can't test it
I understand, looking through comments it says they had no problems, might give it ago just so i can get a few playstation games,
Sorry for your time, thanks for help
any time, post your feedback
One more question, what does it mean by Flash games launcher?
How would you install it via you're phone or over the PC?
