Hello,
I accidently removed the power saving tool from my Xperia U smartphone.
Is there any possibility to re-install the application on my phone ?
Thanks,
Filip
I dont know if you can use this but IN Pack 2 there is power saver widget,
The tool re-appears after a factory reset.
