Hello,
I accidently removed the power saving tool from my Xperia U smartphone.
Is there any possibility to re-install the application on my phone ?
Thanks,
Filip
if it came with the phone, there is a big chance that if you so a factory data reset or a repair using Sony Update Service,
it would restore all of the bloatwares that came with the phone too.
i couldn't find it in play store. maybe bring back with format.
I believe you have to do the mother of all resets: factory reset. Back up your data and apps or settings and the reset will reinstall all your previous apps (those that came with the phone).
This does seem odd, as the power save application is apart of the operating system and can not be deleted from the device. Have you tried simply restarting the phone as some applications may look like they have been removed but in actuality they have not been.
Most of the pre-installed are not removable, indeed.
However, the "Power Save" app is an exception, as are "Neoreader", "Wisepilot", "officeSuite" and "Play Now". These are all pre-installed at the factory, yet they are removable by the user.
I woudl really like to re-install it on my phone. Maybe someone from Sony is willing to mail the app to my mailbox ?
Thanks in advance,
Filip
There are apps that come with the phone that can be uninstalled. Power Saving is one of them.
if anyone willing to help, the apllication is on the \system\app\ folder .. browse with es file explorer
I went there, unfortunately didn't find the file
i have same problem with my experia "go"
can some one please...please help
thank you
Mary
