Sometimes I can't open power menu It just turns off display. Why? Now I'm on stock 4.3[201] I had same problems on custom roms based on stock[for example existenz 3.3].
maybe your power button is faulty
What do you mean? On stock 4.1 I didn't faced this problem.
@Bee-Ant wrote:
If you're rooted, install Xposed Installer, and then install "Gesture Navigation" module on it. There's a swipe function to show Power menu... like, swiping from right edge to the left, etc etc. I've tried it once and it did work on 4.3.
I'm not rooted.
Can someone help me?
with BL locked and .205 firmware who can i root it!?
@J0a0 wrote:Hi,
Flash stock 254 via flashtool[You won't lose be2...]. Then http://forum.xda-developers.com/showthread.php?t=2780836
