Since I have my Xperia V updated to android 4.3, I'm getting power management tips notifications every now and then.
I find it extremely annoying as I can't disable them. Shouldn't these notifications have don't show again checkbox?
The Solution: tap the notification with 2 fingers and slide it down. That opens OK, "Don't show again field". Press it.
What notification do you get?What do they say?
1. to activate Stamina mode
2. to activate low battery mode
3. to activate location-based wifi
i dismiss then, they come back in a couple of days.
well,probably you did not tick the mesage to not appear.
probably because i haven't seen any checkbox at all. any advice on its location?
next time that appear tap on " get it"
when you get nottifaction tap on it and it will come forth then you got check box and "get it"
i'll check it out but as far as i recall tapping on notification just opens power management settings.
Tap longer on the notification.
Great.
