I have just tried to unlock my phone using the power button and the phone is completely unresponsive. I have tried connecting it to the charger, pressed the reset button, everything I can think of the screen is completely black. The phone is still on as it keeps vibrating to tell me I have messages and my colleague tried to ring me and it rang and vibrated, but the screen stays off...
Please help me! I haven't done anything, it has been sitting on my desk all day, it hasn't been near water, been dropped nothing. It's only about a month old...
Thanks!
You know what, I got a similar problem like this. My screen display not worked properly. Notification tones was there but not able to see the screen. Additionally I got a problem like when I press the power button long, I was not getting the shut down and other options. I was trying many ways to resolve this. But finally I just tried one simple way. Removed my SIM card and inserted again
Now everything is working properly.
it does not work at all... if i connect it to the charger its automatically power on at the it appears only 10 seconds ang power off again.. if i disconnect the charger it does not power on...
what should i do,.. help me please...
Thank you so much for the answers it really help!
hallo sir,,i have a sony xperia e4 dual n having an issue on its power button its not working,,,,what can i do for it please suggest me a solution
I have xeperia c3 that the power\lock button does not working. Please help me how make it back to normal.
