Why can't I use the play store? it always says no connection wifi work cause my tab is using the wifi too. No matter how many times i press retry still no connection.
repair using SUS.
Please mark Correct and Helpful answers and you can also visit my blog at:arnabghosal1989's Blog
open your browser and go to
time.gov
does it work?
unrelated topic, if you have some time please check this thread
Nope. But thanks anyway.
I think my phone even facebook doesnt work but im sure the wifi works cause my laptop and tablet is using it and its working fine. Do you think i should buy a new one?
But i cleared the data of the google services framework because google play wont work i got it from here http://www.thriveforums.org/forum/toshiba-thrive-help/15161-we-unable-verify-your-account-time-pleas... after i did wifi and 3g went broken.
repair using SUS.
if that doesn't work then your data plan and/or wifi is not working, at least not with your phone.
repair it with SUS as Arnab suggested
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
