is there any java base application for reading PDF document in mobile phone, now im using ELM
http://gallery.mobile9.com/f/293149/ You can also try this, although I don't know if it's any different from the other one.
Yes, go to Zesium.com, where you can get the Pdfviewer Java app for a one-off cost of $2, last time I checked.
http://pdfcast.org/software/zesium-mobilepdf-mobile-java-pdf-reader Just checked again and this is what I found.
hi
i have just download it but it cannot show most of pdf files(not larg ones.less than 1MB).it say "cannot load'
is it because that it is trial or it cannot show them at all.what is the restrictions for pdf files to show?
thanks
http://talk.sonyericsson.com/message/32250#32250 As you can see from this related thread, that's what other people have found also, so I think there is a size limit of about 1MB. I'll have a look around and see what other info is available.
great..!! thanks you really helpful man and thanks again
Yeah, no problem.I think these Java apps are still under development, so better ones will hopefully be available in the near future.
