Hello,
ive tried to Update my Smartphone(ARC S) , but meanwhile the PC crashed.
The smartphone doenst start anymore.
I dont have access to the drives aswell with usb.
When i try to connect to the PC its repeatly reconnects.
Its through the update set to flash mode now.
Can anyone help me?
Thanks in advance.
if SEUS doesn't work you can use flashtool
Xperia Arc LT15i/a & LT18i/a 2.3.4 4.0.2.A.0.62
