if i connect my sola through pc companion it does not show drivers in safety remove window is it safe to unplug without the safety remove
If you do use a SD (and UMS), you need to safely remove.
MTP used by the internal memory don't need that, hence the missing option. (Still, avoid disconecting when you know it's in use
