I was using my Xperia S yesterday when I realised the homescreen is able to rotate to landscape, but now it does not work anymore. Does anyone know what is going on or was I just high? By the way I am running ICS 4.0.4, it's not rooted or anything. Thanks
homescreen just rotate when xperia s connected to computer via USB cable! :smileygrin:
i had the same issue here XPS 4.0.4
thanks for your tip
can't you just do it naturally?
I also noticed that the home screen can rotate, it did accidentally when it was plugged. Im using Xperia active.
Maybe there is some way to set it to rotate in any circumstances?
