Hi
Since I have updated to 4.3 I cannot connect to PC Companion or the PC don't view it as a external USB device.
Any ideas and "Thanks" in advance
Try clearing data for the app called Media Storage under Settings -> Apps -> All and then restart the phone and see if that helps.
Try settings-xperia-connectivity-mtp mode.
Hi and thanks
It ihas already got the mtp mode ticked.
Force restart your device(power button+vol up until the phone vibrates).Try again.
