Hey guys when i tru too register my phone online ..the application just get forced close!
why is this happening ? and what is the solution?
I noticed that you have a taskiller, you should uninstall it, and also
try
settings -> applications -> manage applications -> all -> tap on each app that it's acting up and clear everything
are you talking about the gmail or sony ericsson sync?
either or, do it on a computer instead of the phone
i tried both acc to register online ..but everytime it shows the Force close option only
you mean update my phone thru comp?
can you elaborate your problem..?
well when i try to Register my phone ..with any account whether it is Facebook or Google or Sony
it just shows the applications has unexpactedly stopped and not responding and i get only option to Force close the app
Please do as recommended by Uliwooly and if that does not work I would advise running a repair via PC Companion.
thank you both
and yes uli it was the TASK KILLER which was causing the problem
I'm glad it's working now
