Can someone please post a noobs guide to downgrade SP from 4.3 to 4.1.2?
I am a complete noob in phone software. I know there have have lot of posts on how to downgrade but it is too complicated to actually do it. I have never fiddled with flashing or any other stuff. Moreover, I live in Canada and cannot find Fido's ftf or firmware. I don't want to lose my LTE functionality. My bootloader is also locked. Please help!
The only Fido I can find is this one https://mega.co.nz/#!4B4y0DIL!qxFhQ9xtBUNK1GL7Ih2xB0QdGd0xgtZIx96fRtRVpmc
Try this one from our site
or
Look on XDA for another one
http://forum.xda-developers.com/xperia-sp
or http://www.xperiablog.net/2012/03/26/debrand-your-xperia-s-tutorial/ Ingnore the title it's the process you need to follow
Thank you Thommo,
That guide is easy to follow.
However, I still can't find the ftf file for my carrier or region. Which ftf file should I specifically install (FIdo Canada)?
Thank you. I will post my result after downgrading
Thanks a ton Thommo. You are a goddamn saviour! It worked flawlessly
