hi, i recently upgraded my x10i to android 2.1, everytime i press the power button to lock the screen it disconnect me from my network, no service message appears, so everytime i press the power button again to unlock the screen i have to enter my pincode and reconnect again, hence, i dont recieve any messages and calls whenever i lock the screen or when screen times out, what should i do with this problem???
One question, do you use task killer apps? some task killers allow you to choose auto kill when screen is off.
I am not sure whether that will kill your connection if you are using one.
yap,,, uninstalling task killer fixed my problem,,,tnx
