Hey,
I just bought a txt pro phone and am having problems with it. First, I want to clarifyy if it's camera has zoom or not, if it does then where because I can't locate it. Plus there seems to be no option for changing the message alert tone. There also seem to be no themes and I don't get to change the time from. If you have the answers to any of my enquiries and doubts please answer below. It will be highly appreciated.
to get ringtones and themes you must go through Playnow page 23
User Guide
http://dl-www.sonyericsson.com/cws/download/1/100/075/5/1308748208/CK15i__UG_EN_1244-7351_1.pdf
first of all, are you aware this is NOT an smartphone nor an android phone? (a lot of users thought it was an android smartphone)
this phone has zoom only on video mode
User Guide
Thanks. You have helped me alot. No, as a matter of fact I ahve only got to know that it not and android after I bought it
they used a similar UIX (user interface) with this phone as with the Xperias
