I have a new Notification Icon (in blue circle in the image) on my SP notification bar since quite some time.I am using no accessary with the phone.It appeared by itself and does't disappear by switching off the phone.Can someone let me know what is icon is about?Thanks in advance.
HI bikramjitz,
This means you have the hearing aid option set within the Call settings. To turn this off do the following.
Menu > Settings > Call Settings > Untick Hearing Aids
i hope this helps.
HI bikramjitz,
i hope this helps.
oops!!! it was so simple.Anyways,Thank you.
Any time, glad I could help.
